stuck hydraulic piston
DONN
07-12-2004 06:56:55
I have a ferguson that has sat for a number of years.The hydraulics would not work so i tore it apart, one of the problems that i see is the piston is froze up in the bottom of the cyclinder. i have soaked it for 5 days with pb blaster and can't seem to budge it. i have tried blowing air into it and tapping it with no results. has anyone else had this problem, or has anyone got any ideas short of finding another cyclinder. thanks,Donn
Jim W
07-12-2004 07:22:47
 Re: stuck hydraulic piston in reply to DONN, 07-12-2004 06:56:55
Try heating up the cylinder with a propane torch and then whacking it, open end down, on a piece of wood. Maybe you could do several cycles of this. Blowing air into it could be dangerous as when the piston comes free it could really fly.
One thing that is sometimes done getting pistons out of master brake cylinders is pumping them full of grease with a grease gun, as they exert huge amounts of pressure. This would involve fitting a grease nipple though so you would have to tap the inlet to the cylinder with the appropriate pipe thread (27 tpi?)
Jim
DONN
07-12-2004 09:54:09
 Re: Re: stuck hydraulic piston in reply to Jim W, 07-12-2004 07:22:47
Thanks for the advice, i guess i'll get the torches out tonight and see if that helps.
