To-30
grampa lee
07-05-2004 20:50:17
have blade on the 3-point. Always worked . Now it will not pick up the blade, With blade off it will go up and down. Oil level is full, Kinda a mikly brown. Any help would be appricated. Thank Grampa Lee
phil(va)
07-06-2004 19:05:03
 Re: To-30 in reply to grampa lee, 07-05-2004 20:50:17
As others said, oil should be replaced based on color u mentioned. And GL-1 is same as mineral oil, and can be found at some WalMarts and at Napa and some tractor stores. However, i doubt that's your real problem. More likely you have a sticky valve in the pump system. Before you replace the oil, remove the right cover and watch the oil (don't put hand in there with engine running) and work lift and see if u can spot obvious spewing of oil or some such. If you need to replace or work on a valve, it's easier with no oil, so time to do it is when you have it drained, not right after you have put in new oil.
John (UK)
07-06-2004 15:51:44
Correct oil for that system is a straight mineral oil...(no detergent) 80 or 90 weight depending on area temerature over or under 50F
from empty 24 US quarts.
Paul in Ms
07-06-2004 05:04:23
Replace the oil. Besure to drain all three drain plugs. Use gl-1 oil only. This should help.
