TO 20 - SN #50451 Timing?
Gene TX
07-05-2004 08:53:27
How do you set the timing on a TO 20? I noticed the spec have an advanced and retarded set point. I changed the points, plug wires, and plugs and it has lost alot of power. I want to check the timing to see if that is the problem.
gshadel
07-06-2004 06:17:09
 Re: TO 20 - SN #50451 Timing? in reply to Gene TX, 07-05-2004 08:53:27
Set the timing on my TO-20 after a rebild. Used the timing plug that is below the starter. I had to remove the bottom flywheel cover first access my flywheel and paint lines on the flywheel. The timing marks are etched on it, but they are darn hard to read with a timing light. Anyway, make a mark at ~7 degrees and a couple more for the advanced setting, 25 - 32 or whatever the manual says. Need a 12 volt battery for the rest... unless you have a 12 volt conversion or a 6 volt timing light and tach. Hook-up tack and timing light, I used my truck battery for the 12 volt power to run them. Run tractor engine, set RPMs to 400. Can't be shy on the timing light, have to get in front of the tractor on your knees to get up to the timing hole to see what the timing mark is with the light. Adjust the timing with the distributor, a little turn makes a big difference. Retighten the distributor and check timing again. The advance timing, just speed the engine up to 2000 rpms and recheck timing again. Luckily, mine was fine after setting the idle timing.
Good luck.
steveormary
07-05-2004 20:42:51
Gene Tx;
We timed our TO-30 by the book(I&T)manual. Takes two people.
steve
