Honest answer for the one you have is "I don't know" - but if you look at the oil flow path for the Standard petrol engine, the mains and big ends get the bulk of the pressure, then the camshaft/timing chain, and finally what is left goes up to the valve train. If the oil isn't well maintained, the (essentially poor) lubrication to the camshaft journals (which are plain bearings, not ball or roller so don't need pullers) gets worse as the hole is semi blocked by gunge - so you get a leak path because of the wear due lack of lube. This means a drop in pressure and a lack of top end lubrication - so rattly valve train and worn guides etc. Rebuilding/resizing/renewing the camshaft bearing surfaces is a major pain (and also $$$$), so doesn't often get done. Rebuilding your oil pump can also be a bonus - if you look back in the archives to sometime in 2003 I posted a load of stuff on rebuilding oil pumps (the company I used to work for made the things, even for the Ferguson engine) and the things to watch out for on clearances, and what makes an inefficient pump. More I cannot offer - HTH.
