TO-30 Brake adjustment
Folsom
03-12-2000 09:31:32
I have a TO-30 and would like to know if the the rear tires will need to be removed to adjust the brakes? Any input would be appreciated
Paul
03-13-2000 05:08:01
 Re: TO-30 Brake adjustment in reply to Folsom, 03-12-2000 09:31:32
Folsom - you should not have to remove wheels. Just back one axle up at a time and adjust. Be sure you block the other wheels so the tractor doesn't roll off the jack. Using a screwdriver or a brake tool, turn the star wheel counter-clockwise (push screwdriver handle toward axle housing) when viewed from the back plate side until the brake lining contacts the brake drum. Then back off until the drums are free to rotate without any. Equalize the brakes by backing off the star wheel on the tight drum.
Good luck.
Paul
