TO -30 HYD. LEAK DOWN
Scotty
06-26-2004 06:24:18
I have a TO-30 that my neigbhor bought completely restored and it runs and looks great but when we hook a 4 foot mower to the back of the tractor and raise it up it slowly drifts down. Is there any kind of adjustment that I can adjust to stop the drifting down ? If so where is this adjustnment ? Thank you for any help Scotty
Chuck in Mn.
06-26-2004 17:15:14
 Re: TO -30 HYD. LEAK DOWN in reply to Scotty, 06-26-2004 06:24:18
If you talking about operation with a rotary
cutter etc. you need an accessory called a chain
bridle kit sold by all rotary cutter companies.
You can also make on by buying a piece of 1/4 or
whatever size chain. This needs to hook up to the
lower link of the cutter and up to the top link
cradle. Company ones have a flat piece of metal
that will go over the lower link pin and has a slot to slip the chain thru and you can adjust depth by changing the chain length in this slot.
If you don't feel creative walk into a Woods or
any dealer that sells cutters. They will know what
you are talking about. Best to do on both sides-
the kit would be. Also you should have at least
one stabilizer kit-low cost accessory on the tractor for this unit.
marlowe
06-26-2004 16:58:30
what do you call slowly? and dose this happen [after you turn the pto of ?]if it stays up for 15minn. or long that is about normal. don't forget you have 50+ years of wear in all hyd. but you can replace the lift cyl. and piston, relief valve,pump valves, gasket on lift piston ,cover gasket, bellie gasket, and pump parts and it still will drope after time that why i ask what you mean by slowly?
