loader
joel from mass
06-23-2004 19:01:56
i want to but a loader on my 1951 ferguson it never had one what do i need and is there a website where i can get the parts or get ideas.
thanks for the help in advance
steve_ne
06-28-2004 09:49:09
 Re: loader in reply to joel from mass, 06-23-2004 19:01:56
This site is the best for information on loaders! Search the archives. Wagner loaders are more common but not the only loaders Paulson,Superior,Freeman Most mount to rear axle using the fender bolts and front axle support pin. If you have narrow front tires you will need to change tire to something bigger. You will need to plum the hydraulic to the loader from the test port in which you will need to hold down the 3pt to force the fluid out the test port. You can find stay braces or you can use a chain. Using this port is slow but will lift enough weight to lose traction on the rear wheels if you have a good internal pump. You will need to find the correct pipe thread to plum from the test port. I used the black gas pipe. Loaders are gravity down and most often trip buckets. some use the frame as a hydraulic resivor on these you need to check to see if there is any leaks in the frame. There is much more but this should give you a few questions to get you started.
phil(va)
06-26-2004 04:21:45
Hello. I put a Wagner Wm3 loader on my TO-30. Got it off a Ford 8N, and it fit well, as they are same length axle to axle. However, like the other post, be aware that these tractors are not the best for loaders. The front is not super strong, and without power steering you will find that you don't want to use the tractor for other chores. Also you must have weight in the back, and lots of weight in your tires or you will not have good traction. I use mine just as a loader tractor and it is fine for that. It takes an hour or two to remove or install the loader, after you learn how. I use a chain hoist to pick it up off the tractor. Biggest issue is getting the front pump "stinger" to hook into the special bracket on the tractor front pulley. New Holland has a kit for the pulley i think, and perhaps MF does too, but I'm not sure about that.
Jim W
06-24-2004 11:11:49
I have a bit on this at my website; I had a loader on m y Fergie when I got it.
My main input on this is just not to put anything too heavy on it. The front end is not too heavy-duty on these tractors.
Jim
