Priming Ferguson Oil Filter
Dave Kierans
06-23-2004 16:38:10
Just rebuilt a Ferguson TE20 engine. Engine is turning over on starter but no oil pressure. No oil in oil filter. Does oil filter or pump need priming? If so, how is this done?
Thanks
DK
Jerry/MT
06-23-2004 18:06:46
 Re: Priming Ferguson Oil Filter in reply to Dave Kierans, 06-23-2004 16:38:10
Are you sure your guage is workinhg and is leakfree?
Assuming you cranked for awhile and the oil pressure didn't come up, make sure your oil supply up tube doesn't have a crack in it and is sealed at both end so the pump primes. I have a TO-30 so I'm not that familiar with the TE20 except what I can glean from the parts manual and the shop manual. According to the shop manual, "The pump inlet tube draws oil from between the oil filter and the screen. Oil is supplied to the filter from the center main bearing...." Make sure the supply tube to the pump is connected tightly and is crack free.
