TO 20 horse power?
ken
06-22-2004 20:11:04
My tractor starts up fine, idles good and has no miss,doesnt smoke, i put a new cap and rotor/points on, the pugs look like the are firing good. But it seems to have no power, even to going up a minor hill, or draggin the back plow, you have to have the throttle alomst wide open and it still dyes out when it get a load on it,, I am puzzled by this, if anyones has some ideas why, i would greatly appreciate them,,,, thanks
Ray,IN
06-22-2004 21:00:02
 Re: TO 20 horse power? in reply to ken , 06-22-2004 20:11:04
The continental engines used in H. Ferguson tractors use the fuel mixture to assist engine cooling under load. This causes the engine to run rich at idle and when not loaded. This is a normal condition. Try readjusting the carb power jet. It is the large thumbwheel screw on the front top of the carb. This screw must never be adjusted to less than one full turn open. The initial adjustment is 1 1/4 turns open. Final adjustment is made with the engine under load, and opening the throttle quickly. If the engine stalls or coughs and sputters open the screw slightly more until the engine revs up smoothly.
