oil filter/wiring harness to20
David G
06-20-2004 12:19:51
I am in the process of getting a to20 running. I took off the oil pan thinking there should be an internal oil filter. I found none, only a sump attachment. The engine # is Z129A600n. Does this engine have an oil filter or is there a way to adapt one to it? Also I need to rewire the tractor, does anyone have wiring harnesses?
Jerry/MT
06-20-2004 20:05:50
 Re: oil filter/wiring harness to20 in reply to David G, 06-20-2004 12:19:51
The Z129 engine was used on the TO-30 and it has a cartridge type oil filter mounted externally on the right hand side of the engine. Check your serial number in the section on the left and you confirm that you have a TO-30. Try the parts folks to your left to see if they have a harness. The wiring on these oldies is pretty simple and you can probably rewire it your self if you can't find one.
james
06-20-2004 19:54:04
David,
I have a TO20 and it does have an internal filter. I think the Z129 is a TO30 and the filter is on the outside.
