hydraulics won't go down
James
06-20-2004 12:17:50
I started my TO20 tractor and the hydrailic lift won't go down ubless there is a heavy implement on it. with the implement on, it lifts and goes down but as soon as I take the linkage to the control spring off the impllement the lift raises and won,'t go down. When it's down there still seems to be some jerking in the system that I have never seen before. I think the relief valve is stuck. Ay help out there?
James
John (UK)
06-20-2004 15:52:35
 Re: hydraulics won't go down in reply to James, 06-20-2004 12:17:50
you are clutching at straws here suggesting all these things...it certainly isnt the relief valve stuck and then in your next mail you think its the main control spring. Stop and check the following. is there any movement in the control spring backward and forward, there shouldnt be any at all. With a 2 bottom plough on the tractor you should just be able to turn that spring...if its slack it needs tightening up...but be careful it may all be rusted up. If there is a LOT of play in it..maybe there is more than just general wear and tear here, possibly something broken or rusted away. By a lot I mean 1/4" or more If that is ok...we need to check the hydraulic lift lever adjustment, slacken off the 4 setscrews that hold the lever quadrant to the housing and move the lever quadrant forward till the implement starts dropping, adjust the hydraulic lever till the rear edge of it is 2 1/4" down the quadrant, that is the "neutral point" it should neither lift nor lower at that point, adjust the whole quadrant till you get it set to that dimension. Hope that sets you straight and gets you going again. Post again if you still have trouble.
James
06-20-2004 17:30:48
 Re: Re: hydraulics won't go down in reply to John (UK), 06-20-2004 15:52:35
John
Thanks for the swift reply. I stoped to think about things and I readjusted the main spring as it was too loose and that fixed the problem. I realized that I had not adjusted it since it was painted last fall. I am taking to a show this weekend in Texas and wanted to preflight it so to speek when this happened.
Thanks Again,
James
James
John (UK)
06-21-2004 10:19:44
 Re: Re: Re: hydraulics won't go down in reply to James, 06-20-2004 17:30:48
Glad it was only that James and not anything more serious...If you have a picture of your tractor I would like to see it....good luck at the show.
James
06-21-2004 18:47:48
 Re: Re: Re: Re: hydraulics won't go down in reply to John (UK), 06-21-2004 10:19:44
John,
You can see a very bad scan at this web site,
Link
Look under Ferguson Brothers and it's the first on the list
Thanks Again.
James
james
06-20-2004 12:19:38
Could it be the master control spring
