buying a mower on a TEF20
Jean-Christophe
06-19-2004 23:47:54
I am considering buying a mower for my TEF20. I will use it once or twice a year at the end of spring when the grass is very high.
I have seen with new tractors that flail mowers make a wonderful job. But how will the TEF run even with a small one ? A rotary cutter is it better ? Which material are you using and what can of problem shall I anticipate ?
thanks
JC
Old Cane
06-23-2004 11:06:52
 Re: buying a mower on a TEF20 in reply to Jean-Christophe, 06-19-2004 23:47:54
One thing that was mentioned to me (and I am glad I took the advise) is to not use mower wider or much wider than your tractor. I could cut fine with a 6' rotary on mine but went with a 5' and it has kept me from hanging it in tight spaces. The rotary bush-hog type mower will cut very nicley as long as the blades are kept in good shape. I use it around the barn and rent house as a finish mower. Mine is only a year old though and has done little brush cutting.
gshadel
06-21-2004 06:56:36
I run a 4 foot flail mower on my TO-20. My TO-20 runs it just fine for routine cutting, it cuts cleanly and makes a nice finish mower. It does tend to really load down my TO-20 if I try to cut really tall, heavy, growth in one pass, where a brush hog mower should really be used instead. I think for routine cutting around the yard, where I'm not cutting grass more than 10-12 inches tall, I think I could probably get by with a 5' flail mower if I had one.
I have seem many people use TO-20's to run 5' rotary finish mowers and 5' brush hog mowers with no problem. I also have a 5' brush hog mower and have never encountered brush or tall weeds that my TO-20 couldn't handle.
Good Luck !
John (UK)
06-20-2004 16:06:17
Hi JC, Flailmowers, will cut practically anything but use a lot of power, the maximum you could use on that tractor is about 1200mm..but you will need an over-running clutch in the pto shaft of the mower, if you dont have one when you press the clutch pedal the mower will drive the tractor because it will act like a flywheel. Possibly a Rotary mower will be better it all depends on what you are cutting...but even a Rotary mower will require an over-running clutch it would possibly drive a 1500mm Rotary mower though. Dont forget that on the TEF the PTO splined shaft is 1 1/8" dia 6 spline...just check that, because your was made in France just at the changeover to the 35 it could be bigger (1 3/8" 6 spline) I would think 1st gear would be a little fast for a flailmower on a TEF well FF30 as yours is. The extra horsepower will be good for the mower though.
Jean-Christophe
06-21-2004 12:13:50
 Re: Re: buying a mower on a TEF20 in reply to John (UK), 06-20-2004 16:06:17
Thank you both
so I understand that the flail mower does really a better job but push the tractor to its limits wen cutting heavy grass, which will be my case.
So a rotary mower, and precisely brush-hog mower is really the best choice for me
thanks for those advices
john, I don't understand exactly what you intend about over-running clutch...
I have seen that mowers have securities in case of violent stop of the blades, but I don't see what happens when the mower acts as a flywheel..perhaps as it is a langage issue for me you can answer by private mail...
John (UK)
06-21-2004 13:28:47
 Re: Re: Re: buying a mower on a TEF20 in reply to Jean-Christophe, 06-21-2004 12:13:50
Its ok JC I found your email address...I am writing to you next.
John (UK)
06-21-2004 13:25:03
Hi J-C Yes I will explain it all to you...can't find your email address sorry, can you email me please "scorpio29 at lineone dot net"
