TO-20 Governer shaft
Mark
06-13-2004 20:14:36
I am in the middle of an overhaul on my TO-20 and am unsure of how to deal with the governer shaft in the front cover. Should I replace the bearing/seal? How do you get the shaft out? I notice there is a roll pin but I can not see a way to drive it out.
Don
06-14-2004 06:47:37
 Re: TO-20 Governer shaft in reply to Mark, 06-13-2004 20:14:36
I would recommend replacing the bearings and seal if the shaft has side play. I recently rebuilt mine. With the timing gear cover laying on a work surface you can turn the shaft at an angle and use a flat end punch to push the pin out. When I removed mine the shaft was so worn that I made a new shaft and also replaced the bearings and seal. Use the old shaft as a pattern to drill the pin holes in the right location and the right orientation to each other. Mine works better than it ever did.
