fuel - oil pump on a TEF 20
jean-christophe
06-13-2004 01:26:07
Hello
I have managed to restore a TEF 20 from 1956. The job is almost achieved (paint, engine) but I have a small question about fuel pump. On my engine, it appears that there is a hole where it should be mounted a fuel pump. When I look photos on the internet most of TEF have this fuel pump installed but some have not. The technical documentation of the standard 20 C does not speak about any fuel pump on this engine, here in France. Any idea ? Is the fuel pump mandatory or not on this engine ?
Thanks
JC
John (UK)
06-13-2004 15:03:54
 Re: fuel - oil pump on a TEF 20 in reply to jean-christophe, 06-13-2004 01:26:07
Just re-read your first mail and I see that you do have a hole in the block for a pump...Well you can fit one if you wish but it isnt mandatory. it depends on how far you want to go with the restoration...as you say some were fitted with one and some not...so it doesnt really matter...Can you tell me if your tractor was one assembled by Hotchkiss in France or was it made in Coventry UK or was the Hotchkiss plant owned by Standard Motors by this time?
Jean-Christophe
06-14-2004 11:18:57
 Re: Re: fuel - oil pump on a TEF 20 in reply to John (UK), 06-13-2004 15:03:54
third party image
it was built by standard-hotchkiss but I do not know about the engine. It seems that it was also built in france under licence
John (UK)
06-14-2004 11:26:32
 Re: Re: Re: fuel - oil pump on a TEF 20 in reply to Jean-Christophe, 06-14-2004 11:18:57
Thank you J-C for that plate.....I always wanted a picture of one.
John (UK)
06-16-2004 10:54:58
 Re: Re: Re: Re: fuel - oil pump on a TEF 20 in reply to John (UK), 06-14-2004 11:26:32
The serial numbers used in France were completely different to UK. The number you gave from your tractor was used in 1948 in UK....the final tractor was numbered 517651 and was made in 1956...quite a big difference in the numbers....Do you know if they carried on production of the TEF in France after 1956 or not...and if so when did they finish making the TE20
jean-christophe
06-16-2004 13:45:48
 Re: Re: Re: Re: Re: fuel - oil pump on a TEF 20 in reply to John (UK), 06-16-2004 10:54:58
you raise a good point
according to my reference book (tracteurs ferguson - jean Noulin - ETAI) Standard Hotchkiss in ST Denis assembled TEF20 from 1951 until 1956....and after produced FF30 from 1956 to 1958 (both with engine standard 20 C Diesel
That confirms 1956 for my tractor and probably that the other had stayed sometime in a warehouse....
John (UK)
06-17-2004 10:59:17
 Re: Re: Re: Re: Re: Re: fuel - oil pump on a TEF 2 in reply to jean-christophe, 06-16-2004 13:45:48
What is the difference between TEF and FF30 then...any idea...or have you got a picture
Jean-Christophe
06-18-2004 00:54:22
 Re: Re: Re: Re: Re: Re: Re: fuel - oil pump on a T in reply to John (UK), 06-17-2004 10:59:17
third party image
In 1956 the french firm had to face a serious competition with Renault (6 gears, until 35 CV, independant PTO, rotor brakes, locked differential...). The trategy was to introduce the FE35 which was not ready in US. So they decided to modernize the T20 and decided to produce (1956-1958) a "new" tractor, the FF30 (Ferguson France). It was grey and red, had the same engines than the T20 but with a better tunning in order to deliver 30 cv. Few ignition engines were produced, and mainly diesel with the standard 20C. Minor improvements were given : new seat, bigger tyres....
It was replaced in 1958 by the MasseyFerguson 35
John (UK)
06-18-2004 10:51:47
 Re: Re: Re: Re: Re: Re: Re: Re: fuel - oil pump on in reply to Jean-Christophe, 06-18-2004 00:54:22
Thank you for that J-C...if you have any more information on the FF30 I would be pleased to receive it....
Jean-Christophe
06-19-2004 04:11:59
 Re: Re: Re: Re: Re: Re: Re: Re: Re: fuel - oil pum in reply to John (UK), 06-18-2004 10:51:47
some more informations :
FF30 models
FF30 DS, standard 20C, diesel
FF30 GS, standard 85, gas
FF30 DE, standard 20 C, narrow FF30 GE, standard 85, narrow
FF30 DV, standard 20 C, vigneron (for people producing wine
FF30 GV, standard 85, vigneron
the standard 85 engine for the FF30 had a "Solex 26 VBN" carburator, the differences in france for the gas engine standard 85 were electrical (french suppliers). The battery was "lucas" (45 AH), the dynamo was "ducelier Paris-rhone", the regulator was "ducelier", the distributor (?) was "SEV" , spark plugs "Marchal", starter "ducelier"
it seems that the choice of the red color for the engine was a local decision to give to the clients the new image of the new firm "massey harris - ferguson"
The ff30 had a single badge on the left side of the hood (at the back) with "ferguson 30". It was red
on demand it was possible to have front wheels 600x 16
most of the FF30 were diesel, because at the same period the french government had decided that diesel was free of tax
power was 30 HP for both engines
the FF30 was the last machine with the name "ferguson"
that's all what I have on this model !
Mike Christie
10-15-2005 10:56:39
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: fuel - oil in reply to Jean-Christophe, 06-19-2004 04:11:59
Hello John
I have an FF 30 DS that I need spares for. It would be useful if I could get engine parts when i am in the UK. Do you know what the base engine was in the FF30DS, e.g. is it a TO30 with French electrics?
John (UK)
06-19-2004 10:36:49
Thanks a lot J-C.....most interesting
jean-christophe
06-16-2004 02:01:22
if you are interested, I learned this morning on a french forum that the TEF n�35817 was registered the first time on january 23 1957. So mine is probably from 1957 and not 1956 as I thought
John (UK)
06-13-2004 06:12:17
The early TEF did NOT have a fuel pump like you say...as long as you fully bleed the system including the tank at the back of the instrument panel (make sure your main tank is nearly full when you try to do that or it wont bleed successfully) everything will be ok. Make sure that there is a good flow of fuel at every bleed point too.PLACES THAT GET BLOCKED ARE THE FUEL TAP AND THE BANJO BOLT INTO THE BACK OF THE AUXILARY FUEL TANK BEHIND THE INDTRUMENT PANEL.
Jean-Christophe
06-13-2004 11:55:28
 Re: Re: fuel - oil pump on a TEF 20 in reply to John (UK), 06-13-2004 06:12:17
Many thanks. And do you think it is possible to add this fuel pump ? Is it better to add it ?
Thanks
John (UK)
06-13-2004 14:58:14
 Re: Re: Re: fuel - oil pump on a TEF 20 in reply to Jean-Christophe, 06-13-2004 11:55:28
It would need a hole in the cylinder block for it to fasten to. It is driven from the camshaft...so if it hasnt got a hole in the block for this you cant fit one...and really it didnt present any problems running without one. Just remember to fill the tank before you try to bleed the auxillary tank behind the instrument panel.
Jean-Christophe
06-14-2004 00:32:31
 Re: Re: Re: Re: fuel - oil pump on a TEF 20 in reply to John (UK), 06-13-2004 14:58:14
ok
many thanks
jc
