Bolt torques
Dave
06-11-2004 14:43:32
Could anyone please tell be the correct torque for the following bolts:
Hydraulic pump to housing bolts
Top cover to housing Bolts
Lifting ram to top cover bolts
Any help is much appreciated
Cheers, Dave
phil fenner
06-11-2004 15:30:58
 Re: Bolt torques in reply to Dave , 06-11-2004 14:43:32
pump base 38-45 ft-lbs
ram cylinder bolts -45-50 ftlbs
lift cover bolts- 38-45 ftlbs
Dave
06-13-2004 09:43:46
 Re: Re: Bolt torques in reply to phil fenner, 06-11-2004 15:30:58
Thanks for the info phil, the reason I have it all apart is that the top cover gasket had blow by where the oil enters form the pump. I thought that the bolts for the top cover might have been a bit tighter than 38-45ftlbs. I have now replaced the gasket, but are tempted to do the top cover bolts up a bit tighter in the hope that this new gasket will not blow like it's predecessor! Are the torques you quoted from the manual and what do you recon with regard to tightenning them a little more?
Any other input more than welcome, Cheers, Dave
sammy h.
05-15-2006 09:30:19
 Re: Re: Re: Bolt torques in reply to Dave, 06-13-2004 09:43:46
hey yallll!
peace*
phil fenner
06-13-2004 22:38:10
Dave, the torque specs came out of the overhaul manual for a TO20/30.
John (UK)
06-13-2004 15:08:09
Its more likely to blow if you tighten it beyond what the specification is...They made an awful lot of tractors and they would all be torqued to that spec...so really I dont think there is any need to vary it do you? They weren't prone to blowing the gasket even the ones that worked very hard with a loader.
Dave
06-14-2004 13:41:46
 Re: Re: Re: Re: Bolt torques in reply to John (UK), 06-13-2004 15:08:09
I took your advise and didn't overtighten, so far so good, no leaks at the mo!
Cheers,
Dave
John (UK)
06-15-2004 10:49:32
 Re: Re: Re: Re: Re: Bolt torques in reply to Dave, 06-14-2004 13:41:46
Good...glad you did that, providing the metal surface is in good condition (no pit marks or grooves)and the face is flat.you should have no problems.
