TEA oil filter head tidbit
Jim W
06-07-2004 20:37:19
I've been puzzling over my hydraulics, so starting the tractor, engaging the pto, turning off tractor, wiggling control valve, starting tractor, etc.
On one occasion I happened to look toward the front when I saw oil shooting out of the (newly rebuilt!) engine at an alarming rate. I mean it would have knocked over a cat! I shut it off at once as there seemed to be a couple of quarts on the ground already. Couldn't isolate it, so started again briefly and found the leak:
The oil filter head fastens to the block with four bolts. Under the head of the lower front bolt was a lock washer, and the oil was streaming out the crack in the washer. Changed to a flat washer, and all fixed. Who would have dreamed? I wonder why it didn't leak from there right from the beginning?
Oh well, better to find it as I did when I could do something about it rather than when I was out in some remote location.
Jim
john(UK)
06-08-2004 12:34:03
 Re: TEA oil filter head tidbit in reply to Jim W, 06-07-2004 20:37:19
Jim, Dare I suggest that the gasket under the head was damaged or the hole in the gasket was too big, and that the oil was coming up the bolt and leaking out of the join in the spring washer, you sealed this join by replacing the spring washer with a flat washer....just a thought.
Jim W
06-08-2004 14:04:47
 Re: Re: TEA oil filter head tidbit in reply to john(UK), 06-08-2004 12:34:03
Maybe, though it was a new gasket of some fairly sturdy composite material.
Well, at this point I will leave well enough alone. Next time I have one of these things off a block I'll examine more closely and try to figure out where the oil travels around.
Jim
