Bent Part
wirehair
06-07-2004 07:52:55
Hello folks,
I am in need of assistance to locate a spare part for my 3 point linkage.
First the story.
I was doing some leveling over the weekend with the box blade. One of the teeth got caught in the tire chain and by the time I got the tractor to stop bucking and dropped the blade a part that connects driver side lower control arm to the axle was severely bent. Passenger side lower control arm popped off the socket on the axle and was loose.
I am going to try and get this part straightened, but I think it has been weakened and would like to locate a replacement for it.
I also put a good size rip in the tire. Any suggestions on fixing it ? I put some rubber cement and compression strap on it, but not sure if this is going to hold.
Thank you for any help you have to offer.
Wirehair
Dennis
06-13-2004 15:00:24
 Re: Bent Part in reply to wirehair, 06-07-2004 07:52:55
I have any parts you would need on a parts tractor I have here. I have the studs that attach to the axle housings and I also have the axle housings if that is what you need! Email me at [email protected] if you are interested in pursuing this further!
Dennis
mowr
06-08-2004 10:57:55
You probably can find your parts used at one of the yards or new at the dealers. It sounds like the tire needs a 'section repair', a heat process that vulcanizes a new section in. Check the truck and tractor tire repair shops in your area to see if this would be a more cost-effective alternative than replacing the tire
