Fergie Newbie Questions
Ozark Pete
06-06-2004 20:38:52
I recently purchased a 1950 model TO-20 from the local Massey-Ferguson dealer. This dealer allegedly sold the tractor new, and I allegedly bought it after the original owner's heirs traded it in on a small four wheel drive tractor. Seems to be a fairly solid old tractor, but a couple of things stump me. The I&T manual says that the tractor has a positive ground, 6-volt electrical system. The battery in mine is hooked up negative ground. When you hit the starter, the gauge shows charge, and when the tractor is running, the gauge shows neither charge nor discharge. The battery has not gone down yet, however. I have read differing views on oil for this tractor, and was advised by the dealer that Shell Rotella 15W40 has been recommended by them and used in this tractor since being overhauled in 1995. I have performed a thorough tune-up on this "ready to go" tractor....plugs, points, condenser, cap, rotor, wires, valve adjustment and boiled out the tank and rebuilt the carb. Runs like a watch. Barely ran when I got it after being "thoroughly checked out and serviced" by said dealer. My next question is this: I have 20-30 psi oil pressure at normal operating temperature. I have heard others claim more pressure, though, again, I&T says 20-30 at full throttle is normal and should not drop below 15 psi at idle, which it does not do. Any advice is really welcome here. I like this little neglected Fergie and would like to give it a better life. Thanks. O.P.
gshadel
06-07-2004 10:43:09
 Re: Fergie Newbie Questions in reply to Ozark Pete, 06-06-2004 20:38:52
Definitely need to turn that battery around so positive goes to ground. Then, follow the manual instructions to polarize the generator before starting the tractor. Lots of different opinions on the oil question. Sounds like you have excellent oil pressure. Keep doing what your doing, sounds like you have a good tractor there.
Paul in Ms
06-07-2004 04:54:46
The to-20 oil pressure is 30 pounds max. If it is still 6 volt it should be postive ground. It will run with negitive ground. If you leave it 6 volt besure to use the big battery cables. The ones for 12 volt will not carry the amps of a 6 volt system. Most people will change to 12 volt but with regular mantinance the 6 volt is fine.
Mr Chapp
06-09-2004 18:51:24
 Re: Re: Fergie Newbie Questions in reply to Paul in Ms, 06-07-2004 04:54:46
Hi Paul, My to20 holds steady 20-30 psi depending on rpm when hot. I'm happy and the tractor seems happy. On the subject of all lubricants please check the archives, as there as many answers as there are oils. Welcome aboard, good luck, have fun!!
