Matthew Davey
05-30-2004 00:14:59
I need help identifying a tractor that i have recently purchased. It is a Harry Ferguson, and from what i can work out by the numbers stamped in the side was built 27th of March 1943.English built by Standard Motors. Serial number TEA 333465. Engine number 9a12381300508. I wanted any info possible.....manuals, diagrams and original configuration etc etc. Any specs would be much appreciated. Matt.
Located in Australia.
Jim W
05-30-2004 06:14:12
 Re: Harry Ferguson Tractor in reply to Matthew Davey, 05-30-2004 00:14:59
It's a 1953; check the website below for some details.
The engine number is stamped in to the block just to the right of the coil. What you have there is the casting number. I would like to add your serial numbers to my website if OK with you - could you get the casting numbers just ahead of the transmission oil dipstick?
The full workshop manual is available and you will hear from others where you can get it.
Jim
Matthew Davey
06-01-2004 04:51:18
 Re: Re: Harry Ferguson Tractor in reply to Jim W, 05-30-2004 06:14:12
Yeah sure you can add the serial numbers to your website if you wish. Im still not to sure what im looking for with the engine numbers i think the tractor may have a different engine in it from standed. The transmission numbers is 2743 i have no idear what these are for. If possible could i have a email to speak dierecticly to you ? If you wish to have mine its MatthewDavey26@hotmail.com
Jim W
06-01-2004 06:43:26
 Re: Re: Re: Harry Ferguson Tractor in reply to Matthew Davey, 06-01-2004 04:51:18
The transmission # probably indicates 27th April, '53. Are there spaces, like 27 4 3?
I have sent you an email; talk to you there.
Jim
