clutch problem
Michael
05-28-2004 20:32:42
I have a 1952 TO30. I recently installed a new clutch disc, pressure plate, and throw-out bearing. I installed the clutch disc, bolted the pressure plate to the fly wheel, and then bolted the tractor back together. When I push down on the clutch pedal, it would move down and come to a complete stop and would not move at all. I can tell the throw-out bearing is contacting the pressure plate fingers, but they will not move. I broke the tractor in half again and noticed that the fingers on the pressure plate seemed to be pulled in all the way toward the fly wheel. It looks like the fingers are moved in so close to the fly wheel that they will not disengage the clutch. I noticed that the springs in the pressure plate look like they are compressed a lot and won't allow any more movement. I don't know what else to do. I have rechecked to make sure that I have the right parts. The clutch is in correctly; the short side is toward the motor, the long side is to the transmission. Everything looks the same as when I took out the old one. Need help!!
mr chapp
05-29-2004 06:12:08
 Re: clutch problem in reply to Michael, 05-28-2004 20:32:42
Michael, if you have a clutch rebuilder in your area they can check clearances for you at no charge or minimal charge. Another thought is, are you sure you have the correct t/o bearing? If you have your old parts, match them up. I once installed a clutch assy. and had a pressure plate that was set up wrong. It presented a very similar problem. Good luck, have fun!!
jim
05-29-2004 03:00:17
had the exact same problem when did clutch on my 1954 to-30 called parts person and explained the problem and asked if was the right disk seemed like disk was to thick so when tightened pressure plate down fingers went all the way in was told was the right disk to make worked ended up shimming pressure plate out from flywheel approx a 1\16 with flat washers and that was 2 years ago and no problem with clutch slippying
Michael
05-29-2004 19:47:42
 Re: Re: clutch problem in reply to jim, 05-29-2004 03:00:17
Thanks for your responses. I really appreciate your help.
