TO-20 Hydraulics
JeffP
05-27-2004 13:48:55
I recently bought a 52 TO-20 that runs great and looks great. I really love this tractor. The problem is that the three point hitch does not work at all. If you grab the arm of the hitch and shake it, it really moves around a lot, almost like there is nothing holding it internally. I'm wondering if the hydraulic pump is totally shot and in need of a rebuild or if there may be something less drastic I can do. All I do is mow with the tractor right now and I don't really NEED to lift anything, but I would like to get it working. Any ideas at all would be appreciated.
Dennis
05-28-2004 05:57:17
 Re: TO-20 Hydraulics in reply to JeffP, 05-27-2004 13:48:55
Jeff,
As you begin your investigation, if you find you need parts, I have a TO 30 parts tractor here that still has all the internal hydraulic components intact! E mail me if you find you need anything!
Dennis
Bob F
05-28-2004 04:52:44
Jeff
It would be worth your time to check out Big Deans Massey Site.(I understand that he is in the hospital right now but I think the site is being maintained) He sells a CD that covers the hydraulics on these Fergusons. I bought one from him a year ago and it helped a lot when I tore into the hydraulics on our F-40.
Bob F.
tokruys
05-28-2004 03:48:16
The previous posts are right, the archives have a wealth of information on this subject. It sounds to me that you may either need to adjust your quadrant adjustment or the fork has come off of the control valve at the pump.
Do you have a manual yet? Good luck.
Phil
05-27-2004 15:26:39
Hello Jeff,
The first thing you need to know is that there is nothing holding the linkage arms down. So, Yes you can pick them up by hand and shake. This does not indicate any problem.
If the arms are not lifting, then you need to check the following,
1. Oil level in the Gearbox/differential.
2. PTO is engaged.
If these are correct and still no lift, then you will need to have a look at the control valve. There is a lot of info about this in the archives.
Good luck.
phil fenner
05-27-2004 14:00:51
Jeff, there is alot of help on this problem in answers to previous questions in the archives. If you review those you will get lots of things to try and look at in your tractor.
Phil(WA)
