to30 pto shaft
jim
05-23-2004 14:44:05
Anybody know where i can get a snap ring that goes around the end of the pto shaft which holds the coller. Thanks very much for your help. Jim
TO35
05-23-2004 17:17:47
 Re: to30 pto shaft in reply to jim, 05-23-2004 14:44:05
I just put one togather, got it from napa, they have an assortment...
Best wishes
TO
jim
05-23-2004 19:28:31
 Re: Re: to30 pto shaft in reply to TO35, 05-23-2004 17:17:47
To35, when i replaced my seal the snap ring was missing is that snap ring thick and hard steel or will the little thin snap ring work ? Thank you for your help and replys.
Jim
TO35
05-24-2004 02:15:15
 Re: Re: Re: to30 pto shaft in reply to jim, 05-23-2004 19:28:31
The one I got from napa was the proper thickness,I have used "two" thin ones (you may have to sand them a little)and had no problems.You don't want to get to much end play
if thin is all you have use two of them and make sure they are seated....
best wishes
TO
