TE-20 cracked block
John
03-03-2000 13:47:44
I looked at a 1948 TE-20 last weekend. The guy said it had a cracked block. He said he puts stop leak in it and he can almost go a season before the oil gets milky. Can a cracked block be repaired? By who? Can you get a new block for a TE-20? How much?
mel
03-12-2000 15:11:08
 Re: TE-20 cracked block in reply to John, 03-03-2000 13:47:44
There was a dealer in my area that used to rpair them. he would: clean the block. drill all the way though the block between the cylinders. put in threaded rod with nuts on the outside. fill the crack with slow drying sealer. tighten the nuts one turn every 15 minutes. the next day he would check for clearence problems and grind the side of threaded rod if needed. then install sleeves.
Mike from Ontario
03-04-2000 06:04:45
John
From the sounds of things every block in every TE-20 in North America is cracked so good luck finding a new block. Yes the cracks can be repaired by welding or stitching them, stitching is a stronger more permanent repair than welding. From what I understand the cracks are usually found between the cylinders in the thin part of the wall.
Mike Leggett
