TEA Generator ?? and Update
Peter(Ottawa)
05-21-2004 15:28:06
I got the idle figured out ,set the top screw , and the idle set screw , now no hunting at idle. thanks to everyone that helped.
I connected the generator to the regulator and temporarily hung the regulator so that I could take some voltage readings. From + to ground , 20 volts at idle , I got the same reading from the - to ground. As I brought up the revs the voltage increased. This seems high and I don't think I should be getting the same readings from both lugs to ground. Any ideas????
