PTO shaft
Jon
05-18-2004 09:10:41
Working on a tractor for an older gentleman and I don't know much about it. I believe it is a TO-30. The PTO is leaking fluid around it. Pulled the plate off and only got the shaft to slide out about 3". This should slide all the way out right?
Thanks
Jerry/MT
05-18-2004 13:11:57
 Re: PTO shaft in reply to Jon, 05-18-2004 09:10:41
It should slide out all the way...unless it has a twist in it! If it does have a twist you'll have to open up the side access plate and cut the shaft to get it out of the hydraulic pump. Look in the archives and there is plenty of info there that discusses this problem.
