Sticky clutch pedal
John Henderson
05-18-2004 04:06:49
I have a slight problem with a TED 20
The clutch pedal sticks about half way out when you lift your foot off, If I put my foot under the pedal and lift all the way it works fine
The clutch doesnt slip and was working fine up until this time
Any suggestions?
Thanks in advance
danct
05-18-2004 16:26:19
 Re: Sticky clutch pedal in reply to John Henderson, 05-18-2004 04:06:49
john
i have a te20 that has been like that for a long time ,i just added an external spring clamped to the clutch pedal and fastened it to any one of the gearbox bolts it dosent bother me and i dont bother it good luck
Danny
James, UK
05-18-2004 06:48:46
John - the return of the clutch pedal to 'normal foot off' position is by the spring action of the fingers on the clutch cover plate pressing against the clutch release bearing - so if your pedal is no longer returning to top position all on its own, I would hazard a guess that one or more of the springs/fingers on the cover plate is worn, broken or FUBAR.
This would also explain why your clutch is still 'working OK' and not slipping.
Fixing the problem does mean (if you cannot stand it any longer) splitting the tractor to fix it though.
If this is the problem I would be a little concerned about further damage to the release bearing/wear on the remaining fingers/strain on the last springs still working - but it is up to you.
Mind you, once you have split the tractor, you might as well replace the whole lot, plus the gearbox input oil seals while you are there.
HTH
