TO-20 Power loss
Clint
05-17-2004 18:03:04
While using a 5' finish mower with my TO-20 and mowing probably medium high grass or so my tractors engine tends to bog down quite a bit. If I am bushhogging it really doesnt do it just while using the finish mower, could this be maybe the carb not out far enough or maybe it isnt even the tractor, could it possibly be the mower (3 yr. old 5' bush hog finish mower) thanks for any ideas.
Ray,IN
05-17-2004 19:31:11
 Re: TO-20 Power loss in reply to Clint, 05-17-2004 18:03:04
Try opening the power jet screw(big thumbwheel) 1/8 of a turn at a time until the engine runs well under a heavy load. The thumbwheel must never be adjusted less than one full turn open under any circumstance. The reason is, Contenental engines use fuel mixture for additional cooling under heavy loads. This causes them to run rich at idle, a desired condition. This is explained in the owners manual.
