to 35 4 cylinder cont. engine crank end play
david shehan
05-16-2004 18:49:15
I am rebuilding a 1953 To 35 continential engine.the crankshaft has a one sided thrust bearing with a brass thrust washer at the front behing the timing gear. my problem is I am getting too much end play when i put the crank in place.what should I do to take up the end play?
TO35
05-16-2004 20:06:49
 Re: to 35 4 cylinder cont. engine crank end play in reply to david shehan, 05-16-2004 18:49:15
The last one I built had the same problem, I just made another shim after some careful measuring out of some shim stock.The next one I do I'll just buy and cut down another washer and use it,cut an oil groove across the face of it for lubrication....
best wishes
TO
Mr Chapp
05-19-2004 19:03:30
 Re: Re: to 35 4 cylinder cont. engine crank end p in reply to TO35, 05-16-2004 20:06:49
I know the standard engine offers different thicknes thrust washers. Does the Continental do the same???
