water in oil pan
Brushy
05-10-2004 19:28:54
Just bought T30 found water in the oil pan. The oil gray like it was mixed with the water. Changed the oil flushed the raideator)SP) started it up ran it for about 20 min. Checked water and oil ok. Checked a few days latter water was back in pan. What are my options. Thank Brushy
Ray,IN
05-10-2004 20:35:32
 Re: water in oil pan in reply to Brushy, 05-10-2004 19:28:54
I would suspect a crack in the block. Run the engine to operating temperature and carefully remove radiator cap to observe the coolant level. At idle the coolant should be still to having a slight movement, at half throttle the coolant should be moving steadliy from the upper hose inlet AND have bubbles rising if the block is cracked. If you determine the block is indeed cracked you have two options: strip the block and have it pinned, or try using a product named Liquid Glass to permantly coat and seal any leaks in the coolant system.
NCtim
05-12-2004 15:56:05
 Re: Re: water in oil pan in reply to Ray,IN, 05-10-2004 20:35:32
Where do I find this "Liquid Glass?"
Ray,IN
05-12-2004 20:20:49
 Re: Re: Re: water in oil pan in reply to NCtim, 05-12-2004 15:56:05
Automotive stores sell it, and I have seen it at WalMart. It is a glass jar holding about 4 oz of product. Follow the directions carefully to obtain the best results.
