T O 30 OIL PRESSURE AND OIL TYPE
FERGY
05-03-2004 09:47:36
My t o 30 has approximatlly 15 p s i oil pressure when its hot ( used oil ) is this normal ? also what weight oil is recomended ? detergent or non ?My hydraulics will raise and lower but wont hold stationary at any height is this normal? thanks in advance.
Jerry/MT
05-03-2004 12:52:40
 Re: T O 30 OIL PRESSURE AND OIL TYPE in reply to FERGY, 05-03-2004 09:47:36
My Ferguson Manual says that Idle oil pressure (hot) should be 15 psi and at 2200 rpm, the oil pressure (hot) should be 25-30 psi.
Jeff-oh
05-03-2004 10:28:12
Yes, 15 psi is okay. An oil change should be made if it hasn't been done in a while. straight 30 wt. is good. People debate over non-det. vs. detergent oils. Your choice. Position control is not inherent in these tractors but can be added with one of several systems available. do a search on position control as this has been discussed at lenght latly.\
Jeff-oh
Ray,IN
05-03-2004 21:55:24
 Re: Re: T O 30 OIL PRESSURE AND OIL TYPE in reply to Jeff-oh, 05-03-2004 10:28:12
Be advised the oil pump pressure relief valve is set to 35psi, so the pressures given in Jerry/Mt's reply is for a new engine. Fifteen psi at operating temp and working rpm's is fairly normal for a used engine. If the valve rocker arms don't make any more noise at idle than at working rpms, your engine should be fine. I use non-detergent 30W30 HD motor oil in summer and 20W20 HD non-detergent oil in winter per the owners manual recommendations.
