F 40 DUAL CLUTCH??
CHRIS
05-02-2004 17:12:08
I AM LOOKING AT A F 40 DOES IT HAVE A DUAL CLUTCH? IT ALSO HAS HYDRAULIC LEVERS IN FRONT OF THE SEAT. DOES THAT RUN OFF THE PUMP IN THE TRANSMISSION? THANKS
don
05-13-2004 13:44:53
 Re: F 40 DUAL CLUTCH?? in reply to CHRIS, 05-02-2004 17:12:08
Your F40 has external hydraulic control valves
used for remote cylinders. I have the operator's
handbook for them. If you would like a copy
call 715 748 6920.
Tim IN
05-02-2004 18:27:10
I believe that it may be an option. All that I have seen do have the dual stage clutch. If you could operate it with a mower, you could be able to tell, as you push down initially the tractor motion should stop and the mower continue to run. As you push the clutch all the way to the floor, then the mower should stop. I believe the letters in the serial number also tell if the tractor is so equipped with the dual stage clutch. In the archives of this site someone breaks down the Ferguson letter codes. I believe the letter M indicates the dual stage clutch, but I could very well be mistaken. I have never seen one with any hydraulic controls in front of the seat.
