to-20 no compression on 1 2 piston
Chris 420
04-28-2004 08:39:35
What could all possible causes be.Should I replace valves, springs andpush rods or should i do something else.
Justin-PA
04-29-2004 08:09:11
 Re: to-20 no compression on 1 2 piston in reply to Chris 420, 04-28-2004 08:39:35
Chris, I outlined a few things for you to check out to figure out your problem, in your first post below. Check that out and get back to us.
TO35
04-28-2004 13:30:23
You may have a blown head gasket that is allowing leakage between these two cylinders which would explain the dropped compression. The more serious question is why. Did the engine overheat, are the head bolts loose?
Check for coolant in the oil as this can indicate a blown gasket or cracked cylinder. Was the engine running prior to this. What happened prior to you needing a compression check?
After all this you may just have to remove the head to see what has happened under there.
Good luck
TO35ga
04-29-2004 03:21:21
 Re: Re: to-20 no compression on 1 2 piston in reply to TO35, 04-28-2004 13:30:23
Hi, just noticed seems we both use the same handle here
I'm Robert from Ga. where are you located?
best wishes
TO
Chris 420
04-29-2004 04:28:47
 Re: Re: Re: to-20 no compression on 1 2 piston in reply to TO35ga, 04-29-2004 03:21:21
The block was cracked and I sent it to get pinned.I am now trying to get it going. I first installed the cam gear wrong then tried to start it.My feilds are turnig to forest.Please Help!!!
Chris 420 IN
04-29-2004 04:31:04
 Re: Re: Re: Re: to-20 no compression on 1 2 pisto in reply to Chris 420, 04-29-2004 04:28:47
INDIANA SOTHERN
