TO35 Sputters Under Load on Hills Taking Turns
JEH
04-25-2004 12:34:14
I have a '55 TO35 Deluxe (Gas) that I use for finish mowing. This year the tractor started sputtering and losing power under load (5 Ft finish mower) while: turning and moving uphill. The tractor, which has been a smoker, is worse this year though. The smoke is grey, not black, worse at idle but present at most times. I've installed Champion D-21 plugs to replace the D-16s. I'm not a mechanic but I do perform my own operator maintenance. The tractor runs pretty well except under the conditions stated above. Any ideas for troubleshooting?
Thank you in advance.
respectfully,
JEH
TO35
04-25-2004 16:30:20
 Re: TO35 Sputters Under Load on Hills Taking Turn in reply to JEH, 04-25-2004 12:34:14
I would start by checking each plug to see if its fouled if its a smoker more than likely you'll find atleast one fouled. if you do find one fouled check compression on that cylinder while you have the plug out, that will determine what you need to do next....if you find no fouled plug then check plug wires and then fuel system and filters both gas and air...this ought to find your problem quickly...if not post back...
Have a nice day..
TO
JEH
04-26-2004 03:29:08
 Re: Re: TO35 Sputters Under Load on Hills Taking in reply to TO35, 04-25-2004 16:30:20
TO:
Thank you for taking the time to reply. I suppose the problem could be caused by one of several faults and the compression test is the best next step. Again, thank you.
JEH
