TO-20 oil change
Fred OH
04-19-2004 11:04:51
Well, here it is time to change the oil it the TO-20 again and be danged if I can remember when I take the bolt and spring and washer out to change the filter...which goes in first...the filter or the spring or washer. Can someone please remind me...it's rough getting older. Fred OH
Duner Wi
04-19-2004 18:12:19
 Re: TO-20 oil change in reply to Fred OH, 04-19-2004 11:04:51
I just did an "oil filer" search at top of page and got 413 hits.
Any way here is what I said about the spring in 2002 and still believe it correct. Lot of different opinions on where the spring goes tho and I could be wrong.
On my TO20 the spring is above the filter screen I am pretty sure just like the book shows . I don't have any spring next to the oil filter either on top or below, maybe I should have?
Anyway the oil is filtered from the inside out and is a partial flow filter. Oil is fed to the filter from the center main after it has lubricated the engine. Oil is metered to the filter via a small hole in the side of the pipe that the filter slides up into the engine on. I would guess only 5-10% of oil gets filtered in one pass thru the engine. I would want the spring on top of the filter screen to hold it down to bottom of pan. If you still have room for another spring I don't think it would matter much if on top or below the filter as the metering hole for the filter is far enough up the pipe to allow oil to the filter if the filter was way up or way down. Anyway that's the way I see it.I could be wrong.
