front axle bolts?
gshadel
04-18-2004 17:53:18
I just bolted-up the front axle to the engine of my TO-20. What torque should these bolts be tightened to? Couldn't find it in my manual anywhere. I tightened them down to 140 ft-lbs.
Also, I was looking for replacement bolts because mine are chewed-up. They look like they have an oversized head and fine threads, and maybe grade 5 bolts. I couldn't find anything like it at NAPA, and several other places. Ended-up cleaning them up and re-using them. Still not too late to change them out if I get a good lead on new bolts... thanks
gshadel
04-19-2004 14:28:22
 Re: front axle bolts? in reply to gshadel, 04-18-2004 17:53:18
Thanks for the info on those bolts. Changing the head sizes over the years probably explains why I ran across two different nut sizes when I pulled the head off my engine. I'll look for some grade 5 or 8 bolts and use some washers... I still haven't found any fine thread bolts that size, guess I'm going with coarse threads, and maybe a dab of locktite.
thanks
Mr Chapp
04-19-2004 19:11:52
 Re: Re: front axle bolts? in reply to gshadel, 04-19-2004 14:28:22
Coarse thread, fine thread... ho hum...as long as they're the same and the torque is the same.., I think a grade 8 is extreeme overkill. Tensil strength is not overly important here. Grade 5 is more than enough. The origionals were probably not even graded. Also the origionals were probably whitworth so we'll never know. Good luck, have fun!!!
phil fenner
04-19-2004 10:58:14
I just completed an overhaul of my front axle stuff and used the sizes and types specified in the parts manual and they are all NF hex type and lengths are also given. I used grade 8 bolts abd the head sizes are whatever comes with them. Use flat washers on the nut side if you want to be original. Not lock washers.
Phil Fenner
Fred OH
04-19-2004 09:24:55
Heres the real deal on bolt heads...at least the way that I see it...1 1/2 times the thread diameter is the hex size. I suppose you're gonna say that means that 3/8" is the size for 1/4" threads...well, try it on the other sizes and you'll see what I mean... example...3/4" bolt...3/4 and 3/8 is 1 1/8...the correct size wrench for todays bolt... suppose it holds true for the nuts also. That's how the experienced mechanic goes to his wrenches and brings back the right one without missing. There, you might have learned something. Anyone got a formula for the cussed metric bolts and nuts? Fred OH
mr chapp
04-19-2004 09:40:39
 Re: Re: front axle bolts? in reply to Fred OH, 04-19-2004 09:24:55
Answer to 2 questions. 1st, rhe bolts on my to20 have been changed to sae and, as mentioned before, washers have been used. 2nd combination for metric... convert as close as possible to sae ie, 8mm=5/16 10mm, close to 3/8. No I dont know of a true formula, but I seem to remember a chart availible through Curtis or Bowman fasteners. All will vary according to fine or coarse, wet or dry and so on. Fred, if i run across the chart I'll let you know. Good luck, have fun!
Jim W
04-18-2004 20:22:42
Yes, they have oversized heads compared to modern bolts. The 1 1/6" heads on the 5/8" bolts will be 15/16" now. For the ones that connect the radius arms to the fron axle I used washers as the heads didn't look big enough to me. I think I heard that some standardization occurred since these bolts were made and they did not pick these head sizes (same with the nuts). In any case I suspect with 140 ft lbs yours won't come apart anytime soon ;)
Jim
PS Sorry don't know the spec.
