TE-A20 wont run
Ian
04-15-2004 09:43:24
At our farm we have a te-a20 that came with the farm we had it running for a while but it didnt run very well then it quit working so it sat in the middle of the field for the winter now if we try to start it the tractor wit start up and run fine (it runs fine now because 2 and 4 plug wires were switched) it will run fine fo about 10 seconds then it will just shut off like someone turned it off.could it be the coil also could somebody tell me all the setting for it like the timing ,plug gap and any other info because we found out that we were getting stuff for a z120 engine not the standard engine
it is a
1951
TE-A20
Jim W
04-15-2004 17:14:05
 Re: TE-A20 wont run in reply to Ian, 04-15-2004 09:43:24
Sounds like what happens when you don't have enough gas flowing. When the tractor is off some gas slowly fills the bowl in the carb, which is enough to keep it running for a few seconds as you describe.
Points 0.015" Plugs 0.025" Timing TDC Valves 0.013" hot.
Jim
PS If you go to the links page on my website, and select the bottom one on the left (it's in German) then pick Handbuch, you can find the rest of the specs.
ian
06-19-2004 21:27:34
 Re: Re: TE-A20 wont run in reply to Jim W, 04-15-2004 17:14:05
its gettin plenty of gas because it starts dripping gas out of the carb ans the it is a 12 volt not a 6 volt
