MF 50 Starts won't run
Chuck Gassiott
04-13-2004 21:04:30
Hi, a few years back I rebuilt the engine of my MF50. got it sealed up and started but moved to take another job in another town. 4 years later I am moving back to my folks place and try to get the 50 going. I let someone talk me into putting a zenith upgrade carb on. Anyway now I can start it with starter fluid and it runs until the starting fluid is gone. I have fuel going to the carb but can't get it to run. Have pulled carb and cleaned- no stuck needles or float. Reset carb to basic setting for start up according to Zenith. even with the throttle diconnected from the govenor and manipulated manually i can't get it to stay running. any sugesstions.
txblu
04-14-2004 11:04:26
 Re: MF 50 Starts won't run in reply to Chuck Gassiott, 04-13-2004 21:04:30
you missed a varnished port somewhere. You could start with removing the bowl so that the float can fall and see if you have a good flow of fuel. Then look 3 times for those tiny .010 and .020 holes. Unscrew your brass and look thru it to a light source. Clean the cast parts where the brass was screwed in. It will work. You just aren't there yet. Compressed air and Berryman's chem tool. Wonderful combination.
txblu
