Ok, Newbie here..clutch question....+ 3 point
Glen
04-13-2004 18:08:26
Since it looks like i will be splitting the TO 20 to fix the rear main seal and whatever knock is in the engine..i was wondering if it is possible to adapt to a dual stage clutch? Is there a kit to do it anywhere or am I dreaming the impossible?
Also..on a 3 point..how do you adjust the top link properly?
More newbie questions to come...thanks for all the help from this board already !
phil(va)
04-15-2004 18:14:36
 Re: Ok, Newbie here..clutch question....+ 3 point in reply to Glen, 04-13-2004 18:08:26
When hooking up normal implement (post hole digger is an exception), hook up left lift arm, then right lift arm (since right one has an adjustment, do it second), and then the top link. The top link is normally adjusted so it is tight but not so tight it is holding up the implement at strange angle. In other words, if hooking up bush hog, don't make it so tight the rear wheel is not on the ground, etc. Adjustment of top link for a plow is critical to how deep you want to cut. Maybe that will help some. The other post answered your other question.
Glen
04-16-2004 01:58:06
 Re: Re: Ok, Newbie here..clutch question....+ 3 po in reply to phil(va), 04-15-2004 18:14:36
Thanks ! That tells me what i needed to know..
Jeff-oh
04-14-2004 15:09:15
Dual stage clutch will not work in the TO-20. The PTO is driectly driven from the drive shaft. There is noting to dual stage to.
