Knock at front of engine
marvin
04-12-2004 13:16:40
There is a new governor new rod bearings an no end play in the crank or camshaft.
Counld it be the oil pump? It is at the front of the motor?
Help
Crem
04-14-2004 21:04:39
 Re: Knock at front of engine in reply to marvin, 04-12-2004 13:16:40
Make sure that your front pulley is tight.
mowr
04-14-2004 12:30:27
For your sake I would like to be wrong but my experience with these has been that if the main bearings are not replaced during overhaul, they go out very quickly once the engine is back to full strength.
marvin
04-14-2004 21:13:26
 Re: Re: Knock at front of engine in reply to mowr, 04-14-2004 12:30:27
Mowr the knock was in the motor befor i sarted to rebuild it.the main are go an the rod are new. I think the oil pump may be bad or one of the gear at the front of the motor.
Jerry/MT
04-13-2004 20:49:43
End play should be .003 to .007 inches. Maybe it's too tight.
marvin
04-12-2004 13:18:58
It is on a TO30 1951
