Adding hourmeter to TO-20 Fergie
Grass Roots Far
04-10-2004 16:20:53
Bought an hourmeter from JC Whitney, rated for my 6 volt positive ground TO-20 Fergie. Instructions are not tractor specific. Where should I connect the + and - leads from the hourmeter. Thanks in advance.
John, IN
04-10-2004 16:48:49
 Re: Adding hourmeter to TO-20 Fergie in reply to Grass Roots Farmer, 04-10-2004 16:20:53
+ to + & - to -
Grass Roots Farmer
04-10-2004 17:27:24
 Re: Re: Adding hourmeter to TO-20 Fergie in reply to John, IN , 04-10-2004 16:48:49
+ to which terminal? - to which terminal? My generic instructions are vague.
John, IN
04-10-2004 18:20:57
 Re: Re: Re: Adding hourmeter to TO-20 Fergie in reply to Grass Roots Farmer, 04-10-2004 17:27:24
+ on the hourmeter would go on the positive ground side. In other words put the + on the meter on the + on the battery. The - on the meter would go on the ignition switch on the terminal that goes to the coil.
GrassRoots Farmer
04-11-2004 06:40:00
 Re: Re: Re: Re: Adding hourmeter to TO-20 Fergie in reply to John, IN, 04-10-2004 18:20:57
Thanks, I will give it a try.
TODD(MI)
04-11-2004 06:52:54
 Re: Re: Re: Re: Re: Adding hourmeter to TO-20 Ferg in reply to GrassRoots Farmer, 04-11-2004 06:40:00
Let us know how that works out and maybe some pics. I was thinking of adding an hourmeter. I just don't know exactly where I want to mount it. I have a water temp gauge that is going in the dash. I'll have to find a spot somewhere.
Todd
Grass Roots Farmer
04-15-2004 17:04:11
 Re: Re: Re: Re: Re: Re: Adding hourmeter to TO-20 in reply to TODD(MI), 04-11-2004 06:52:54
Hooked up the hourmeter today and it works just fine. + wire of the meter to a grounding screw on the dash and - wire to the coil side of the ignition switch. I mounted the meter on a 2" hole I drilled in the dash next to the oil pressure guage. I now have 4 guages--ammeter, water temp., oil pressure, hourmeter--on the dash.
Fred OH
04-15-2004 09:02:46
I would put it under the dash where a couple of mounting holes for a bracket wouldn't be so obvious. Fred OH
