TE20 PTO loses power under load
Paul Malt
04-02-2004 02:57:11
Does anybody have any idea why the PTO on my TE20 loses power (ie. stops) under load.
If the load is removed it starts to spin again...
James, UK
04-02-2004 03:10:30
 Re: TE20 PTO loses power under load in reply to Paul Malt, 04-02-2004 02:57:11
If this happens with the tractor stationary in neutral eg while running a sawbench, it is probably the clutch slipping which you can adjust as per the manual - unless it has worn completely, in which case it is time for a new clutch.
Try braking in 2nd gear to see if you can get the same effect of clutch slip to confirm this - I know my old TED seemed OK before its new clutch, but under load on the road it would slip.
