Front end Spacer bolts
Terry
03-28-2004 09:22:46
I am in process of putting on a bumper on my to35. I have the nuts off the bolts but am unable to budge the bolts. Before I start to hammer them out I was wondering if they were threaded in the hole? I assume they are just rusted in and with Liquid Wrench and time they will come out?
gshadel
03-30-2004 13:20:36
 Re: Front end Spacer bolts in reply to Terry, 03-28-2004 09:22:46
I pulled the front mounting bolts on my TO-20 a few weeks ago. Ran into the same problem. The first one came right out, but the rest needed a lot of PB Blaster, a propane torch, assorted tools, and some swearing to finally get them out.
I want to get new bolts when I re-install them, the old ones look mighty rough. Looks like the bolts are a fine thread, but I'm assuming I don't need a special grade bolt, like a grade 5 or 8 for the new bolts. Any thoughts on that would be appreciated.
kesiladi
03-29-2004 18:04:42
Have you tried lifting the front end and taking all the weight off the expanding bars ? Could be too much pressure on the bolts.
Jim W
03-28-2004 23:09:01
They are not threaded. Heat, penetrating oil, patience, a long breaker bar, sweat, repeated efforts, beer, and appropriate comments are all that's required.
TerryMI
03-29-2004 16:09:49
 Re: Re: Front end Spacer bolts in reply to Jim W, 03-28-2004 23:09:01
Jim, thanks for the reply. I will keep applying the PB Blaster & have plenty of cold ones on hand this weekend.
