reverse rail oil seal
Mark
03-27-2004 19:45:43
The shaft that goes from the transmission into to the bell housing to engage the starter switch has a seal on it. Mine appears to be leaking. I have the tractor split and figure while I am there should replace. Does anyone have the seal # for this seal?
Thanks
mark
03-28-2004 06:21:19
 Re: reverse rail oil seal in reply to Mark, 03-27-2004 19:45:43
Forgot to mention the tractor is a T0-20
bub
03-28-2004 04:30:03
is it the main shaft bearing retainer gasket? part # 181 476 m1 says replaces TO-7086
Mark
03-28-2004 05:59:17
 Re: Re: reverse rail oil seal in reply to bub, 03-28-2004 04:30:03
No, I do not think it is that. The reverse rail is above that shaft and there was oil dripping out of it. The IT manual shows a seal there.
