Dearborn Dirt scoop
TerryMI
03-27-2004 17:47:37
I was looking in a tractor boneyard today for a dirt scoop (3 pt). I found a Dearborn scoop that I was not able to read the model #, Anyway I couldn't tell if it was a reversable scoop or not. I have done a search on implements pictures and there are no Dearborn scoops listed. Anone have an idea or thought on the Dearborn scoops?
Terry
03-28-2004 09:19:18
 Re: Dearborn Dirt scoop in reply to TerryMI, 03-27-2004 17:47:37
Per Question from JD/MO, All scoops that I have seen do hook up to top link, per the damage to draft control I have no answer. Thanks to Gerry for letting me know that it is not a reversable scoop.
JD/Mo
03-28-2004 09:09:58
Hi Terry, I recently bought a dirt scoop that is reversable, and after useing it in both directions, I like to use it in the reverse position. I'm wondering, if you know, does this hurt the draft control/ pump assembly under the seat, or should I be attaching the top link to a different point. sorry I can't help you with the Dearborn scoop thing, I thought you probalby would know more about how to use a scoop than I do. Thanks JD
gerry
03-28-2004 06:33:39
i have a dearborn scopp and it is not reversable.
steveormary
03-28-2004 17:25:49
 Re: Re: Dearborn Dirt scoop in reply to gerry, 03-28-2004 06:33:39
Terry MI;
I dont see where using a dirt scoop in either direction would do any damage to the draft control or hydraulic system. Just take it slow and easy when you load the scoop.
steve
gerry
03-28-2004 17:46:04
 Re: Re: Re: Dearborn Dirt scoop in reply to steveormary, 03-28-2004 17:25:49
no it wont hurt the system. i think the newer scoops are reversable. its easyer if you can turn it aroun and scoop somthing up than to pull scoop depending on what your doing.
