TO 20 hard to start when cold
jeff
02-17-2000 19:55:25
I have a TO-20 that is hard to start when it is cold or has sat for more than a few days. It fires right up with a shot of ether. I hate to use the ether. does anybody have any ideas???
Mike from Ontario
02-21-2000 07:17:41
 Re: TO 20 hard to start when cold in reply to jeff, 02-17-2000 19:55:25
Jeff Is it a TO20 or a TO35 with a diesel?
jeff
02-21-2000 17:36:14
 Re: Re: TO 20 hard to start when cold in reply to Mike from Ontario, 02-21-2000 07:17:41
Definately a TO20
george
02-20-2000 19:16:00
Jeff
can you check the compression in your engine? Low compression may cause the problem you are having with cold starts. Do you get a lot of blue smoke when you tractor starts? Burning off oil might indicate low compression and results in fouled plugs which might contribute to hard starting when cold.
jeff
02-21-2000 17:42:35
 Re: Re: TO 20 hard to start when cold in reply to george, 02-20-2000 19:16:00
The engine was just rerung last year although I haven't checked the compression. Any Ideas as to how much compression is good? It smokes very little on start up. jeff
george
02-23-2000 18:28:12
 Re: Re: Re: TO 20 hard to start when cold in reply to jeff, 02-21-2000 17:42:35
Yeah
I have been told that 100 psi is real good compression. I have checked mine before at cranking speed, I got around 90 psi, one of my cylinders is only 75 psi. My TO-20 runs real good but smokes a lot when I first start it.
If your compression is OK, you may also want to check your carb. It may be running lean, or the choke not closing right when you try to start.
good luck, let us know how you do
Curtis Cain
07-18-2001 10:24:53
 Re: Re: Re: Re: TO 20 hard to start when cold in reply to george, 02-23-2000 18:28:12
I want to convert my TO20 to a 12 volt system can I use the 8N system or what do I need. My Fax is 641-774-8543. Can you help me ? Thank you.
Greg Chalmers
02-20-2000 13:38:54
The only problem with ether as far as I know is that it removes all lubrication from the cylinder walls causing premature wear. Some folks swear by using WD40 in an aeresol can suggesting that it ignites and isn't as 'dry'
