quadrant setting for position control
JD/Mo
03-22-2004 14:50:55
I finished my new position control device per the instructions from the "N" board, and in trying to set the finger tip lever I find that my neutral position is 4-5" below the 21/2" that my brand new service manual calls for. Can the lever be adjusted up by loosening the split nut that holds the lever and friction plate to the quadrant? Or do I just live with what I have and make the necessary adjustments to the linkage between the quadrant and the lift arm pivot?
I hope you guys can understand that (not sure I do) and thanks for the help, both present and in the past. I am learning to check the archieves for answers but found nothing on this.
Thanks again JD
MAKE UR OWN POS CONTROL
03-26-2004 17:06:19
 Re: quadrant setting for position control in reply to JD/Mo, 03-22-2004 14:50:55
see make your own
tractorfix
03-24-2004 14:02:23
You adjust the fingertip control by loosening the mounting bolts and sliding the whole fingertip unit fore or aft. Once you get that set up, your position control should work mint.
Jeff-oh
03-22-2004 17:35:55
JD,
I guess it depends on which Position control device you are using. Is it a purchased system, like the Thang or Fergy position controler, or is it the make it yourself version as presented in the news letter and pictured on the N board.
They work slightly differently but shoud adjust easily.
Jeff-Oh
JD/Mo
03-23-2004 07:24:04
 Re: Re: quadrant setting for position control in reply to Jeff-oh, 03-22-2004 17:35:55
It's the do it yourself control from the ford n newsletter. Made it myself.
NCtim
03-23-2004 14:32:28
 Re: Re: Re: quadrant setting for position control in reply to JD/Mo, 03-23-2004 07:24:04
Where do I find a copy of that?
JD
03-24-2004 05:22:07
 Re: Re: Re: Re: quadrant setting for position cont in reply to NCtim, 03-23-2004 14:32:28
Hi tim, I got the instructions for makeing the position control from Jeff-oh a few day's ago. Check the archives and if you can't find anything leave me your e-mail and I'll forward his message to you. Havent got it working yet (my fault) but looks like it'll be pretty slick when it does. good luck JD
NCtim
03-24-2004 13:10:33
 Re: Re: Re: Re: Re: quadrant setting for position in reply to JD, 03-24-2004 05:22:07
Can you email me? [email protected]
Jeff-oh.
03-23-2004 12:20:41
Great, I would love to hear how it works for you.
The position control should be independent of the neutral on the fingertip lever. Without the position control attached, you should be able to set the height of the implement and trim it out so it is not going up or down. This neutral setting should be set per the service menual. Then when the position control is hooked up the cam on the lift arm will adjust to the correct position.
Is it possible that the fingertip control is out of adjustment to start with?
Jeff
JD
03-24-2004 05:16:38
 Re: Re: Re: Re: quadrant setting for position cont in reply to Jeff-oh., 03-23-2004 12:20:41
I'm pretty sure control arm is out of it's proper setting location. My "neutral" (the location of the finger tip contol arm, where it is at full up and just starting to lower) is about 4-5" below the 21/2" down that the manual calls for. I'm thinking I can set the 3 pt. at full up, loosen the split nut on the control arm lever to reduce pressure on the friction pad, set the lever at the proper 21/2" location and retighten, and be in conpliance with the instructions in the shop manual. Does that sound right?
Jeff-oh
03-24-2004 06:30:59
 Re: Re: Re: Re: Re: quadrant setting for position in reply to JD, 03-24-2004 05:16:38
There is a procedure in either the owners manual or the shop service manual. Of which I have neither with me today. I'll look it up and let you know.
Jeff
NCtim
03-22-2004 15:26:26
Are you talking about the Zane thang?
