Lift Cover Leaking
GaryH/OH
03-22-2004 14:40:39
I have a Ferguson TO30 and when ever i use the lift it leaks fluid between the lift cover and the
housing. I install new gasket but it still leaks.
Any ideals.
Ray,IN
03-22-2004 18:47:27
 Re: Lift Cover Leaking in reply to GaryH/OH, 03-22-2004 14:40:39
Ther hydraulic oil is pressurized at the pump, passes up through a steel tube into the cover and to the lift cylinder. The seal between the cover and hydraulics casting is usually reliable and doesn't leak. On some models an "O" ring is used to prevent the pressurized oil from leaking, you'll find a recess there if your tractor uses this seal. Have you torqued the lift cover bolts? I use an gas/oil resistant RTV gasket maker in a pinch. Could there be a small burr or crack near the leaking area? A large, flat, smooth file may be used to clean up the mating surfaces if used prudently.
