T020 lift problems
Robert Yow
03-22-2004 09:29:05
My lift is very sensitive.It only has one small spot that it works in. You have to move the lever half way down before the lift lowers,then the lift drops fast. Theres no fine adjusting.
Phil(va)
03-22-2004 20:13:03
 Re: T020 lift problems in reply to Robert Yow, 03-22-2004 09:29:05
The 20 and 30 do not have position control. It is either up or down. That works great for plowing, but not so well for bush hogging. Lots of info and discussion on this in the archives if you do a search. Also on the Ford 9N board, as the 9N and 2N Fords have the same issue. You can buy a Zane Thang for about $80 from Zane Sherman in Talledega, AL (look him up on the 9N Board) and that will give you position control. There is or was a competing product from Australia called the Fergy Positioner, but I'm not sure if they are selling that here in the "colonies" anymore. I have one of each on two different TO-30s and both work.
