Packing on rear main bearing cap on Z-134?
Darrell
03-22-2004 08:59:13
I am rebuilding a Z-134 engine for a Ferguson F-40. The gasket kit came with a ball of cotton string to use for the seal between the rear main bearing cap and the block. Can anyone tell how many pieces of the string should go on each side and if they should be twisted? This is one step that I don't want to do by trial and error. Thanks
Duner Wi
03-23-2004 18:32:30
 Re: Packing on rear main bearing cap on Z-134? in reply to Darrell , 03-22-2004 08:59:13
I have never worked on a Z134 so this may not appy but if I have a cavity to fill with string I put a little RTV in the hole and push the string in the hole with a 10d nail that I have ground the point flat. main thing is to get it packed to bottom of hole. I keep adding small amounts of RTV as I progress. Some people do it this way with out the RTV . I have used this method with success but not on a Z134. Good luck.
Darrell
03-24-2004 13:57:15
 Re: Re: Packing on rear main bearing cap on Z-134? in reply to Duner Wi, 03-23-2004 18:32:30
Hi
Thanks for the input. I was wondering if it might help to coat the string with the silicone gasket sealer. I am sure that Contiental would have used it had it been available in '56. Also would anyone know if four strings are used at one time.
Thanks in Advance.
Duner Wi
03-24-2004 15:10:21
 Re: Re: Re: Packing on rear main bearing cap on Z- in reply to Darrell , 03-24-2004 13:57:15
I would suggest coating 1 sting at a time with RTV and pack it solid in the hole with a small tool that will drive string to bottom. There are probably faster ways but this has worked for me.
GM in the 80's said to wick the hole full of sealer. Easier said than done . I want to be sure the hole is full of something. Good Luck.
