to20 lift
frank
03-21-2004 15:12:06
help. replaced gasket on hyd pump under tractor center. had to remove pump of course. replaced and lift arms will not work. have removed twice more and installed according to manual and will not lift. what could i have done wrong?
Paul in Ms
03-22-2004 04:24:40
 Re: to20 lift in reply to frank, 03-21-2004 15:12:06
Frank it could be something simple. First check to see if the pto is spinning. Take off the inspection cover to see if the linkage from the quadrant is moving the control valve in the pump. If the pump is working you should have turbulence at the pump or where ever the leak is at.
frank
03-22-2004 05:51:55
 Re: Re: to20 lift in reply to Paul in Ms, 03-22-2004 04:24:40
to paul. thanks for the reply. all you mentioned is happening. that is the mystery. all worked fine until i removed the pump to replace the gasket. is there possible some priming time involved when the system is drained?
Jim W
03-22-2004 14:02:31
 Re: Re: Re: to20 lift in reply to frank, 03-22-2004 05:51:55
How about grunge in the system? Was it pretty cruddy in there? Wondering if a glob of gunk is plugging a passageway in the pump, or maybe the standpipe.
Jim
